create mlag peer
create mlag peer peer_name { authentication [ md5 key {encrypted encrypted_auth_key | auth_key ]}] }
Description
Creates an This command is available on all Universal switches supported in this document. peer switch association structure.
Syntax Description
peer_name
Specifies an alpha numeric string identifying the MLAG peer.
authentication
Authentication for MLAG checkpoint connection.
md5
MD5 authentication type.
key
Authentication key for checkpoint connection to the MLAG peer.
encrypted
Authentication key in in encrypted format.
auth_key Authetication key used for checkpoint connection.
Default
N/A.
Usage Guidelines
This command creates an MLAG peer switch association structure.
You must use a unique name for the peer switch. If you attempt to create an MLAG peer with a name that already exists, the following error message is displayed:
ERROR: MLAG peer with specified name already exists
The following command creates a peer switch structure switch101:
# create mlag peer switch101
This command was first available in ExtremeXOS 12.5.
Platform Availability
